Discuss Combi Boiler Low hot water pressure in the USA area at PlumbersForums.net
I have I have an Ideal C35 boiler. We have really low water pressure from all the hot taps (should be getting 15 litres per min if using more then one stood completely).
On Friday Ideal came out and changed the diverter valve, heat exchange and motor but it has made no difference.
The cold taps are fine and the pressure into the house has been tested and is fine.
Anyone any ideas on what could be the issue?
The water pressure from the hot taps had been absolutely fine up to the last few weeks.
Check the cold supply lever to the boiler ( blue one I think ) is fully open . Has the cold water flow to the kitchen sink altered recently ?
Just checked cold supply lever is fully open and no alterations to the kitchen sink recently.
Get the inlet filter checked and cleaned
Then you might need to cut in some tees on the cold into the boiler and hot out to confirm the boiler is restricting the flow
As Scott has said get the inlet filter checked and cleaned and also the flow turbine . Kop
Reply to Combi Boiler Low hot water pressure in the USA area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
