Discuss Combi boiler flue leak in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have a Vaillant Ecotec combi boiler. The flue pipe extension has started to leak at one of the joints. The internal plastic connection pipe appears to be intact. It still drips when there isn't a demand for the boiler.
I've attached some pictures and moved the joint strap to see. Can anybody please offer any advice and guidance.
Many thanks...
I would argue yes tbh the whole flue run needs replacing also the electrics need to be looked at also
The electrics are getting sorted Wednesday weve just had a doorway into the garage put in and light switch moved. It's a temp so weve got a light to work in there. I'll get a gas man in to sort the flue đź‘Ť
Reply to Combi boiler flue leak in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
