Discuss Cold water tank in the attic overflowing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Cold feed to cylinder on the one tank. The other tank has a cold feed to the pump for the bath (both hot and cold tank fed)How many pipes come off the two larger tanks you have a cold feed to the cylinder. Anything else?
Pump does whole house, hence I thought if I used the isolation valves on the pump it would stop any backfilling mains. But either the isolation valves aren’t turning off fully or im barking up the wrong tree. However I can feel the pipes on the pump they are cold as if mains water is flowing through.Sorry I’m getting mixed messages with this does the pump do hot and cold water for the whole house or just for one shower
Kitchen mixer is pumped, turns pump on etc.Kitchen mixer won’t be pumped
Yes. 3 taps and shower are all like that.Only on hot, the cold should be straight from the mains
Reply to Cold water tank in the attic overflowing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
