- Messages
- 35
Evening all.
I have open vented C/H system with a heat only boiler and 10 rads over 3 floors.
I have just replaced a rad on the middle floor. Drained system down for new gateway valve for cold feed for header tank. Refilled system no leaks, , but the top top 2 rads won’t get hot.
ALL rads contain water, I have bled all rads. No hot water getting to flow pipe of either rad on top floor.
All other rads are working.
When I bleed the top cold rads, all I get is cold water.
Any ideas or help in helping me would be much appreciated
The top 2 rads are run in 15mm. All other rads get hot.
Cold Water actually squirts out of bleed valves in top 2 rads that don’t get hot. These 2 rads are about 10 years old. The others that all work fine are 24 years old.
Any advice would be much appreciated
Simon
Simon
