Discuss Cold rads hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
craigy
S plan system with 2 x 2 port valves. Rads cold and hot water ok, the valve for the coil in the cylinder is operating ok visually (black switch arm) the other valve operates when tapped but seems to knock itself off after a few hours.
The valve is a range product with a red wheel on the side with a flat edge indicating it is open. When it is tapped it does a full rotation and the heating kicks in.
Any help appreciated
c
Haha,
thanks very much, would you recommend changing the entire unit or just the head.
Was getting into the tapping.
Reply to Cold rads hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
