Discuss Clip your Polyplumb or this! pic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil
Sent from my GT-I91 uploadfromtaptalk1346955045239.jpg00 using Tapatalk 2
New build estate and my 4th polyplumb blow off, pipework in loft an unclipped tangled mess, everytime they turned off a tap this tee wobbled and eventually worked loose, or it wasn't tightend in the first place.
I worked on new builds for several years and every single house is first fixed like that
new build work is crap but then so are the prices pay peanuts get monkies i love the notch in the bottom of the joist a few years ago we did 16 houses in wanstead and the nhbc bloke came on site twice and only left the office once
When I did site work the money was great ( All price ) but they did employ monkeys 1 lad came to me and said how do I pipe up the basin.
Another classic case of installers ignoring the manufacturers installation recommendations. 15mm plastic should be clipped every 300mm. There is no excuse for that tee blowing off as the pipes could easily have been clipped to the joists.
When plastic is done properly, it is quite time consuming and expensive what with clips every 300mm, inserts in every fitting and the cost of the fittings themselves. Copper and soldered fittings are just about on a par with the cost of plastic.
Incorrect installation is what gives plastic such a bad name.
He didnt pressure test it then?
a pressure test cant stop a fitting being effected by poor clipping and movement. Without clips plastic wipps around like a garden hose hence every 300mm a clip should be fitted. it may have helped if it had the correct sized lagging as it may have weighted it down alittle more.
I wouldnt say its as time consuming as copper , the big bonus of plastic is you dont have a fire hazard so dont have to lug around fire extinguisher nor sit around an hour after soldering (in theory)
You don't have a fire hazard, but do have the problem of rodents eating it and flooding the building. I've seen this several times.
In a straight race against the clock, I bet I'd won with copper against plastic on a straight 30m run!
Reply to Clip your Polyplumb or this! pic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
