Discuss Clean air intake - position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mr K
Where a gas hob is installed in a room with no direct door or window connection to the outside a clean air intake must be provided. This is well documented elsewhere including the cross sectional area, sleeving, etc.
My question is where can that intake be positioned? Is there a minimum height, internally or externally? I'm guessing there might rules so that it cannot be blocked by flooding, drifted snow, frost, etc but so far I cannot find anything documented.
Advice anyone? Ta muchly.
Hi there ?Mr K and welcome along to the forum,
If you read technical bulliten 00?
If you are gassafe registered get your post count to 10 and pm a mod to gain access to private gassafe forum for proper advice , if your not gassafe registered then you should get an engineer in to do this right,
Reply to Clean air intake - position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
