Discuss Cistern keeps overflowing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My cistern kept overflowing randomly was told it was probably caused by the bottom filling valve failing I purchased one and
a plumber fitted it and tested it and all seemed well, we where away for a couple of weeks and came back and there was no evidence that it had been overflowing but after using the toilet for a number of times it seems worse than before! the level of the water in the tank is set at about 1/2 below the overflow pipe. the feed to the cistern is from a header tank and not the mains, it is slow to fill the cistern. Any ideas?
With a gravity feed you are better off with an “old fashioned” float valve- it will be quicker to fill than an equilibrium valve and is usually easily repaired.
However; if yours is not shutting off there could well be some debris obstructing the diaphragm seal - this is easily cleared using a mug as described on box/instructions.
Do you have an isolation valve to this toilet? Things can be improved if this is a full bore valve rather than a regular bsll-o-fix type.
Pictures of you set up and inside cistern would help.
Here's my setup had been working for over 20 years without a problem
Yes ignore the pipe that’s for USA toilets trap primer
Reply to Cistern keeps overflowing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
