Discuss Cistern Float change in the USA area at PlumbersForums.net
Hello. Need some help please...I have a concealed cistern and the side entry float keeps getting stuck. I have done jobs such as changing these things before but a little bit hesitant as unfamiliar with the connection I can see before me. I know its a compression one but can I undo the nut without needed a new compression fitting ? Any advice would be welcome please e.g how do I go about changing the side entry float and any recommendations on which one to buy that will fit a concealed
cistern...Appreciate the help.
I cant remove shelf as all siliconed in. Please check pic, i dont think access would be an issue....many thanks
Firstly remove the shelf and the cistern lid then post a photo of the fill valve if you need further assistance.
You have three connectors:
1. The nut which joins the white plastic pipe to the threaded shank of the toilet's fill valve. This is what is known as a tank connector. It is not a compression joint but has a 1/2" (pipe size, not physical size) fibre washer inside it which seals against the flat edge of the inlet shank.
2. The nuts at top and bottom of the isolation valve. These are compression nuts. In theory you shouldn't have to touch them, just turn the water off at the screwdriver slot between them.
Your pipework does not look as if it is square, but appears to be pushed away from the cistern at the top. This may make it more difficult to install a new inlet valve, but it shouldn't be too hard.
Many thanks. Im going to order a side float. So hopefully, if i undo the nut on the tank connector I should be able to tighten it back up?
Wouldn`t do that just yet, would wait until you see what you have there and how much room for the new one.
Reply to Cistern Float change in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
