Discuss Chp in the Plumbing Jobs | The Job-board area at PlumbersForums.net
missplumb
has anyone had much to do with combined heat & power units, we are looking at possibly going into the biomass CHP market as the Rhi on <200kw biomass boilers will be practically killed when the 25% drop comes in july.
Looked at it a couple of times, not gone there .. yet.. which manufacturers are you looking at ?
It has good possibilities, for reasonably sized power users - the key is in using all the power that's produced and in needing heat all year round. I can think of a few installation environments when it makes sense.
Been looking at the froling chp, 100kw heat, 50kw electric. But I think we will be looking for bigger +500kw systems. Need to look for hospitals, gyms, swimming pools, etc as you say somewhere that can use the heat all year round
Reply to Chp in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
