C
cascas
What is the correct treatment to use on a conventional heating system (inc microbore) before fitting a new combi
What is the appropriate chemical - not sure if it should be X400 or X800
What do other use?
X400 - System Restorer - A non-acid treatment for cleaning older heating systems, restoring circulation to radiators and pipework. A ruthlessly efficient way to eliminate the build-up of magnetite sludge,
X300 - System Cleaner - Seems to suit new systems.
X800 - Jetflo Ultimate Cleaner is a heavy duty cleaning formulation designed to remove corrosion deposits and scale from boiler heat exchangers, radiators and pipework in domestic central heating systems.
[h=1][/h]
What do other use?
[h=1][/h]
