Currently reading:
Cheap Knipex
Discuss Cheap Knipex in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tamz
There is a lot of discussion about this make of grips or that and generally good grips are quite expensive.
I found these tonight. What seems like a set of alligators without the dipped handles which if they are they are the cheapest i have ever seen.I bought 2 pairs.
When i get them in i'll do a no bs review and tell you what they are like but at £4 a go they are not expensive and look worth a punt.
eBay - The UK's Online Marketplace
Draper is the official Knipex distributor and many vendors wrongly label Draper products as Knipex, if it does not say Knipex on the tool it is not a knipex tool, in this case i think the quality is reflected in the price.
Looking forward to hearing your review - at that price they're not far short of disposable (or at least it wouldn't break your heart if they got lifted)
It doesn't seem to say Draper or Knipex on it. I don't think they are, especially at that price.
Alligator VDE's are @£18 - 20 and Cobra VDE @ £30
Any cheaper please let me know the location!
Cheers
think i seen some at makro today, they are the 'draper diy' ones and the jaws dont open too far!.
The grips came in today so as promised here is a wee review and a comparison to other grips. (The only old style alligators i have are insulated ones, only the handles are different)
The grips are officially Draper Expert's (61755 4003). They look very similar to alligators without the dipped handles. Differences apart from that are they are handed the way they are made compared to knipex and don't have the knipex stamp. They open the very same distances at all settings and grip nuts at exactly the same points. The casting finish is slightly rougher than on knipex but comparable with rothenberg.
Photo's
Trying them on a piece of 1" steel compared to others, steel pipe in the vice and swinging on them with 16 stone of weight, and the drapers bite and grip as good as either of the knipex. The only ones that slipped were the rothenberg
I think for everyday use if you were constantly using them, the lack of plastic grip may bother you but apart from that the build quality is very good. They are nothing like any of the other draper pump pliers offerings. Time will tell on the quality and hardness of the steel used with the wear rate of the teeth. I'll let you know how they wear in a month or so.
Scores
New style alligators 9/10
Old styles alligators 8½/10
Drapers 7½/10
Rothenberg 5/10
The new style alligators score higher because they open further. The drapers loose a point from the old style alligators for no plastic handles and the rothenbergs are quite junk anyway.
So there you have it. For 4 quid they are not a bad set of grips in fact for 4 quid they are excellent. There is a few places selling them about the internet. Buy a set and make your own mind up.
Good review, i agree with your ratings as i own all the above grips although lately ive fallen in love with the old style footprints but still carry the knipex new style grips for something narrower and they open up to a pump nut size.
Thanks for the review tamz - just ordered a couple of pairs - at that price it's got to be worth giving them a go.
Still fitting into a 34 waist tho lol
You must be 7 foot tall and realy slim to have a 34" waist at 16 stone! im 6,2" and 18 and a half stone, my waist measurement has a 4 in it but aint 34. :stooge_curly:
6 ft 2" 34" waist 48" chest just short of 16st. Blame it on cast iron baths and cutting fireplaces out. Been around 15½ since i was about 20 odds but i've put on about half a stone in the last few years.
In that case you must look something like Stan of American Dad! :tongue3:
And they've arrived.
Don't look half bad (especially for the price) - machining and fit of the jaws and pivots looks sharp and accurate.
Not as comfy to use as dipped handles but certainly worth having around in different tool boxes / bags so you've always got a pair when you need them.
Is the country of origin stamped on the pliers?
i got these pliers free when i bought an opti-vision level from a draper salesman, they are decent looking and not bad but not having grip's at the bottom of the pliers make's them horrible to use and i probably will never use them again.
its quite easy to put the proper handle grips on them if you can be bothered.
i think you can get cans of liquid like plastic that you can dip the handles in
That would not be a bad idea as the grips themselves are decent enough
i think it's called something like plasticoat or plastidip i've seen it somewhere maybe on ebay
i am a bit proficient in this actually as i have been making fishing lures.
what you need is the wifes best saucepan, a stove, old tool grips (soft ones) or pull it of the wifes brush.
put the grips in the pan then slowly heat up and stir continously untill the pvc melts. if it starts to smoke heavily then its the wrong plastic.
after it reaches 240c it will turn liquid, take of the heat and dip grips into it, leave for 20 seconds then dip again until thickness required. it may be necessary to warm up pvc again.
thats how they do it in the factory but with virgin pvc, so yours may come out dioreah brown.
What you need to do redsaw is buy a heap of these cheap grips off e-bay then modify them with your plan above then sell them off for 15quid!
Reply to Cheap Knipex in the Plumbing Jobs | The Job-board area at PlumbersForums.net
