Discuss Changing switchmaster 400 for lifestyle lp241 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - I currently have a switchmaster 400 connected to a back boiler and hw cylinder. The controls are " timed/off/constant" and "water or heating & hot water"
How do I wire-up the lp241 as there are only 2 black wires on the existing set up ? When I use terminals 3 & 4 the hot water fires up, but when I select the central heating, the pump comes on but the boiler doesn't fire up !
I can't seem to find any information on the lp241 and can't get my head around the wiring diagrams online
There is NO thermostatic control on the system other than trvs
Thanks Steve, but I've got it wired on 3 & 4 as per the table. When I select heating only, the boiler doesn't fire, but the pump comes on ?
Cancel That ! All sorted - changed the pin at the back, as it was set for a pumped system - all working ! Many thanks, Rob
Reply to Changing switchmaster 400 for lifestyle lp241 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
