Discuss Central heating pump leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jamiesmuma
Hello
I live in a rented house.
We have just established after a very soaking carpet, that the central heating pump (or more so the litle tap that sticks out of it) is leaking. It is a back boiler, oldish, hot water tank upstairs. The leaking is coming from the little tap head under the pump. What could be causing this? seems to have occured once we started using the heating, didnt have this prolbem when we turn the hot water on.
Just wondering if this is costing us money, i.e using gas? obviously when the heating is not on I hope its not costing us gas, but when it is, is it sucking all our heating? OH was complaining the radiators weren't hot the other day when the heating was on.
thank you
Landlords problem to sort out ... Interesting that you don't seem in the least bit bothered about the carpet or the leak, just weather or not it'll be costing you!! I'll take it the carpet wasn't bought be yourself?
Water damage top of my list. Might just be the gland nut. Should be on the phone to the landlord asap.
No it wasnt. I haven't lived here long. I am concerned about the carpet I have had it all up to air dry, cleaned off the mould underneath, towel dried the concete underneath (thus used 3 towels that I will now have to bin) and I have also borrowed a carpet cleaner to clean it and suck out any moisture. I feel I am doing more then most tenants to be honest.
If it was using tons of gas for god knows how long, then yes I am going to be more concerned about that since I have done all I can for the carpet (it isn't damaged YET, just very wet but drying out now, few specks of mould that I have cleaned). I have had problem on top of problem here. The LL is going to sort it out but I dont know how long its been leaking for
If it was using tons of gas for god knows how long, then yes I am going to be more concerned about that. I have had problem on top of problem here. The LL is going to sort it out but I dont know how long its been leaking for
Long time if it's mouldy. Shouldn't have used any extra gas.
I currently have a bowl under it, it was collecting lots. Turned off heating and now it seems to have stopped, so its related to the central heating. Ill try limit the heating I have on, but its already very cold in here. LL is going to send out a plumber soon I think.
Wasn't much mold, specks of it on the underside of the carpet. We haven't been having the heating on for ages (on and off for about a month or so). LL is quite good, so I think ill get a plumber soon, just didn't know if it was going to be a massive job or not? from looking at it, it just looks like the tap thingy needs tightening?
What you describe could be a drain point fitted under the pump. If it is it can be possible to tighten up! CAUTION - they can sometimes get worse rather than better when you tighten them :)
Ohh I wont touch then, I will probably make it worse. Yeah its the tap thing under it thats leaking, you no the things that stick out the end of radiators? sorry I am the wrong gender to know what I'm talking about!
Ill leave it to the professionals
Thank you
put a picture up so we can be totally sure what is leaking although it does sound like a drain off as already said.
Reply to Central heating pump leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
