Discuss Cast iron radiators and heat pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gary
Hi chaps.
I know that low heat systems work well with under floor, but i was wondering if cast iron rads are a terrible idea or not. They can absorb and distribute slower so should work well, No???
Cheers for your views.
Good idea in theory, they would need to be huge though to work with the lower flow temperatures
I posted a similar question about radiator outputs and heat pumps. I have just found this which may be some use to this question
[DLMURL]http://www.pipecasings.co.uk/downloads/download%20files/Radiator%20Output%20Calculator.pdf[/DLMURL]
Hope that helps
Rads work fine with heat pumps but as said are generally doubled up. Problem with old style rads is they seem to already be double sized for standard boiler so would be massive on a heat pump
Used this combination before and it has worked ok. Just make sure rads are sized correctly.
Used Daikin air to water heat pump with cast iron rads and it worked fine. Just make sure you size the rads and heat pump correctly. You can always use a Daikin high temperature heat pump. Goes up to 80Deg.
Reply to Cast iron radiators and heat pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
