Discuss Cartridge change on a concealed shower mixer in the USA area at PlumbersForums.net
Hi there.
I installed this concealed 4 way shower diverter and thermostatic valve in the early 2000s. I think it was an Ultra Helix from memory. The diverter (top) is leaking and needs replacing (or just the ceramic and seals).
I cant for the life if me remember how I get the face plate off. The temperature stop on the thermostatic valve (bottom) is stopping the face plate from sliding off.
I actually changed the thermostatic cartridge about 3 years ago so its certainly possible.
I have tried Allen keys down the centre of the splines but nothing seems to grab. Ive tried pulling the thermostatic part reasonably firmly.
Any advice would be greatly appreciated - Including memory enhancement techniques....
I found a diagram for a similar but non diverting mixer.
I think the temperature override housing must be corroded onto the thermostatic cartridge.
Shame I cant get to it to spray some WD in there.
I will gave it some leverage and a little persuasion with a hammer tomorrow.
Face is probably just stuck on with silicone
Thanks and good call but the silicone has been removed. I can move the face and peek behind it a bit. I think because of the leaking diverter it may have corroded the temperature override housing onto the thermostatic cartridge. Thats my best guess at this time anyway.
Reply to Cartridge change on a concealed shower mixer in the USA area at PlumbersForums.net
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in...
I've just replaced an Ultra SASF2 – M thermostatic shower cartridge together with the spring mechanism and the temperature sensor. My problem is...
Hi. I have Charlton Mixer Tap in my shower i.e. thermostat and water control. I need to change the cartridge in the tap as it is dripping badly...
I installed Jaquar Fusion thermostatic bath shower mixers during a conversion in 2007. I let the properties out. They have lasted pretty well with...
