Discuss Capping off radiator above the floor, please advise. in the Central Heating Forum area at PlumbersForums.net
Hey guys,
Quick question for all the I knowledgeable plumbers out there.
I need to remove one radiator which is first in line, as that room is being knocked down. Unfortunately I can’t cap off below the floor as it’s tilled. What’s the best course of action here?
Cap it off above the floor (will that not create air locks in those pipes?)
Join these two pipes together for continuity, but will I be able to get flow for the other two radiators down the line?
Thank you for any advise on this!
Lumen
Compression cap ends but surly it will cause a tripping hazard?
Also if it’s being knocked down the floor will have to be patched ?
Thank you for your reply Shaun.
The part where radiator was, will be boxed in, but I'm not sure what's best:
1. Cap the tails off 30-40cm above the floor (these will trap air?)
2. Join them for continuous flow, will this reduce the flow for the 2 radiators down the line?
Thanks,
Lumen
Can’t join them only option is to cap or lift the floor and remove the tees
Be fine you could put some air taps / vents on top but as your boxing it in no point as these won’t be accessible
Reply to Capping off radiator above the floor, please advise. in the Central Heating Forum area at PlumbersForums.net
Good afternoon, Just looking for some general advise, I'm renovating my kitchen and need to disconnect my kitchen sink pipes while I re-plaster...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
N
Hi! We're looking for a consult for our 1905 built (renovated in 2010) victorian house for the future of our heating system. The house is 2...
