Discuss Can't pull out lever mira shower after removing grub screw in the USA area at PlumbersForums.net
I would like to replace the lever of Mira shower so I removed the grub screw but cannot pull the current lever. It is stuck, if I pull too much the whole unit may fall. I sprayed some lubricant without success. Any ideas? Thanks.
Reply to Can't pull out lever mira shower after removing grub screw in the USA area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
