Discuss Cant identify the make of my shower mixer unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rosy65
We live in Jersey and purchased this shower unit about 10-11 yrs ago from a local supplier. The mixer thermostat needs replacing as there is no adjustment left to adjust the hot/cold mix. No one has been able to identify the make and the supplier only has records back 9 yrs!
Can anyone help from these pictures? (sorry pics need rotating clockwise 90 deg to view correctly)
[FONT=arial, verdana, sans-serif]For some reason we think it might have begun with a B but we can't swear by this![/FONT]
Reply to Cant identify the make of my shower mixer unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a shower which has always been too hot no matter how you adjust the mixer temperature but recently it's really burning hot. The shower is in a loft conversion and the plumbers teed off a downstairs shower to feed the bathroom upstairs. There are two isolation valves downstairs for hot...
We are in a new build (2 years) and the bar shower value on-off bit is jammed. I want to replace it myself as can't afford a plumber. The old one is is Aqualisa and has on/off on right and temperature on the left. I have purchased a replacement bar shower valve with the on/off on left and...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
So recently we had a shower with exposed pipes and I decided to sink the pipes into the wall, Ive completed that task only to find I havent sank them deep enough. Issue now is when I put the shower mixer on it sits off the wall by around 20mm or so. Even worse is the shower has been tiled and...
1K
Firstly , apologies if this is inappropriate. I'm really not sure what questions I should be asking. I had a bathroom refit done around 7.5 years ago, including a digital shower. It's been great, but recently has really started playing up - the controls to raise or lower the temp seem to make...
2K
