Discuss Can moisture get trapped behind shower cladding? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello. I was replacing a shower tray and took off some old waterproofing silicone. Then the next day, there were some water droplets coming from behind the cladding. When I was removing the glass panel and taking off old silicone, there was some water droplets coming out from there as well. Could there be a leak or moisture trapped behind the cladding?
Only one way to find out other than leaving it for a week to see if it drys up
Thank you for your messages. The water seems to have dried up. Possibly some moisture went in from a tiny hole on the cladding.
Should I put any water proofing at the back of this tray? Also, this is the best I can fit it in, is it good enough to be siliconed now?
Not sure you can do much waterproofing now the panels are in. Careful bead of silicone around and follow mi's esp on the silicone on the door and frame. If the timbe behind was dry when you exposed it, you're in good shape.
Reply to Can moisture get trapped behind shower cladding? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi all Plumber who fitted shower frame didnt put sealent behind frame to tray before fitting frame. Now leaks when water gets into frame and...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
