Discuss Can I add another pump? in the Ireland area at PlumbersForums.net
Just after abit of help really
I've installed a 35kw Worcester system boiler in a property, over the last 6 months the customer has purchased the house next door and converted 2 houses into 1.
A lot of the pipework I couldn't get in to check/change due to various reasons but the primary run is 22mm all the way as far as I can see with branches of 15mm.
There is 24 radiators on the system of which 6 are small towel rads all upstairs except the furthest away get red hot and all downstairs bar the 3 furthest away get hot if I turn 4 or 5 years off the ones furthest away belt round but as soon as the others are open again it loses the heat
I've shut down all lockshields as much as I can which helped slightly but not enough
What I'm asking is can I install another pump onto a system boiler down the far end of the property where it's struggling to get to and how do i go about doing it?
Reply to Can I add another pump? in the Ireland area at PlumbersForums.net
PSxxxxxx
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
