Discuss Can I add a seperate header tank to a fortic cylinder? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
G
Geddoffme
Hi I just bought a house with a combination hot water cylinder & cant replace the heating system yet as we have walls to knock down etc where the new radiators would be & the new layout will require different sizes.
My GF needs a more powerful shower its a trickle atm. I ordered a pumped power shower then discovered you need a large cold water tank, the discovered its a combination cylinder.
We only need it short term. Could I fit a 50gallon tank above the combination cylinder and just use the bottom half of the cylinder & conect all the pipes between the two to the new header tank? It isn’t pre-insulated btw.
No sorry the new tank would fill the cylinder tank and overflow it
Yes it’s the vent with a standard cylinder this is brought upto the cold tank
With your combined cylinder it just dumps back into the little tank
Reply to Can I add a seperate header tank to a fortic cylinder? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
