Discuss Can anyone recommend a good tap spanner? in the Plumbing Tools area at PlumbersForums.net
currently an apprentice and just changed over some basin taps my tap spanner isn’t great and slips off a lot, can anyone recommend anything decent and not too expensive?
thank you
Armeg jaw dropper are the ones I use the most
If it's a basin spanner - as per link by Moonlight, they take some getting used to.
All fairly much the same design, it comes down to the teeth on the jaws and also the user.
They are an awkward tool to use and require some practice in using them.
Reply to Can anyone recommend a good tap spanner? in the Plumbing Tools area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
I removed the old vanity unit in my bathroom, intending to do a makeover. Finished the shower cubicle, and starting on the vanity. I bought a 2nd...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work...
