Discuss Can anyone reccomend a decent lead lock please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Hi
In the process of swapping out a stopcock in 1930's house and it is on an old lead pipe. I have not done one onto lead before. I am hoping to connect to the existing ftting but if not would look to replace the one there.
Any reccomendations please? Thank you in advance.
shave the lead clean carefully and use the right lock and all will be well
Make sure you can isolate from the boundary valve before you start.....regards Turnpin:yes:
Reply to Can anyone reccomend a decent lead lock please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
