Discuss Can anyone identify this flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
camfish
Hi I would grateful if anyone knows what this flush valve is as never come across it before cheers
Its a push button type of some make. I fitted a similar one the other day.
Thanks that is the one I couldn`t take it out as the custard nearly cut his finger off peeling his spuds so had to run him to the local A&E all part of the service
It's over-designed rubbish is what it is. Your new one will break like your old one did. Fit a fluidmaster.
These are standard in most Twyford bathroom cisterns. Most merchants stock them. I loathe them and if you get stuck, I'll send a truck load down with the ones I've removed and replaced with a Fluidmaster.
i only fit fluid master i was assuming the op did not want to remove the cistern
Yes I gave him the option to fit a fluidmaster but he wants the same valve fitted looks very fragile but it's his money
Reply to Can anyone identify this flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, can anyone identify this flush valve, there are no manufacturers marks on it, the seal needs replacing, thanks.
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a...
Hi there, can anybody help? I am trying to buy a replacement toilet flush push button as my current one is broken? However I cannot find the same...
My toilet flushes ok when the long flush button is pressed - but water continues to flow into the toilet bowl. No problems with the short flush. I...
1K
