Discuss Can anyone give advice to fix my shower tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tuloula
Hi - I would be really grateful if anyone can advise on how to fix an issue with my shower tap. I have one where you can switch between tap and shower head by pushing the lever from left to right. Today when I put it on shower mode, a lot of water started gushing out at the point where the shower is connected. I disconnected the shower hose, and the item came out as in the picture attached. I have no idea how to replace this to get the shower to work again! Can anyone help?
Thanks,
Tuloula
best advice your after is get a local plumber to have a look
Hi and welcome to the forum, Its possible you have lost some part/ parts down the drain. If not it may be easy,but if you try to put the pieces together and see how they fit. I would say its hel together with a screw or some sort of cover
Reply to Can anyone give advice to fix my shower tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My puppy ate my shower head where it connects to the hose. It's an expensive shower head (hand held) how do I fix just that piece? Is it possible?
Hi my triton shower suddenly had no water coming out after Thames water doing work outside my house, the shower just started buzzing with no water...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hi. Can anyone help me get into this tap? I have them on the bathroom sink and bath and 2 out of 4 are dripping. I've have had two plumbers in to...
