Discuss Can an Ideal Logic Heat boiler be controlled with opentherm? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
ringi
If so any issues with using the Honeywell CM Zone system to provide load compensation and zoning?
Do I need to add a something onto the boiler to connect it to the Honeywell system?
What do I do about controlling the hot water tank?
(I am sitting in the cold study and thinking I wish I could get more heat without having to term up the thermostat in the hallway that is already warm enough for when I am working at home)
Reply to Can an Ideal Logic Heat boiler be controlled with opentherm? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
1K
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
Hi all, i moved recently in new home and realised that there is no room external thermostat wired to the Ideal Combi boiler. There is only...
Dobsuk
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
1K
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
