Discuss Can a Propane Manual Change-Over Regulator Kit Be Used For Butane in the Gas Engineers Forum area at PlumbersForums.net
Can a Propane Manual Change over Regulator Kit be adapted to switch between regular Butane Gas cooker cylinders?
Naturally, the correct/matching Butane fittings and hoses will be attached.
I'm just wondering if there are pressure differences between Propane & Butane cylinders that could cause problems.
Aslong as the bottle connections are the same yes
Reply to Can a Propane Manual Change-Over Regulator Kit Be Used For Butane in the Gas Engineers Forum area at PlumbersForums.net
