Discuss Can a DIYer replace an expansion vessel in the Oil and Solid Fuel Forum area at PlumbersForums.net
I got same problem!
I drained water till zero on water guage, then inflated the EV, The water guage went up, shud that happen?
Keep draining while you pump up and wait until the water stops then pump some more until you have no water coming out and the shrader gauge says 1 bar
Reply to Can a DIYer replace an expansion vessel in the Oil and Solid Fuel Forum area at PlumbersForums.net
PSxxxxxx
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
