Discuss Can a combi in a cellar supply a radiator in the loft? in the USA area at PlumbersForums.net
If you have a Vaillant ecotec 28 in the cellar - supplying 7 radiators - 3 on ground and 4 in first floor - could that also supply a radiator in the attic?
So I need to add an extra pump to the Combi boiler on the central heating circuit?
Most boiler pumps are suitable but if you have doubts then using a Grundfos pump calculator (which can be found online) and by inputting some data it will give you recommended options, you could then see if your pump is suitable.
It may be that a second pump is recommended but when you start adding multiple pumps you then need to think of hydraulic separation.
Without going into thermodynamics, do what you want.
If it doesn't work, then go to Plan B and put a second pump in with a hydraulic separator.
I doubt whether you will have any issues with your existing setup.
I've done plenty of jobs where additions to the houses, technically means the boiler is undersized.
I generally tell the customer to keep the existing boiler and see how it copes. ( if the boiler isn't too old )
If it doesn't cope, we'll upgrade the boiler at a later stage.
Reply to Can a combi in a cellar supply a radiator in the loft? in the USA area at PlumbersForums.net
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
M
I am currently in the middle of a complete rennovation of my house and need some advice on what kind of boiler to get. The house will have 4...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
