Discuss Can a boiler with a timer be converted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a boiler where you have to set the mechanical timer like this one
Is their a way I can convert it to a thermostat which is digital or even one of those hive style ones I can control from my throne.
I find the mechanical timer to be temperamental and I don’t like it
No, I meant throne :p
These are pictures of it.
How would it be done and what I you think the cost would be if any of you have experience if this?
1. The boiler can easily be converted to use external controls.
2. Figure 45 on page of the installation manual contains the necessary wiring diagram.
3. The basics of it are that the internal clock is disconnected, and the external controls wired in its place.
4. How it would be done and cost will entirely depend on what controls you want.
5. If it were a traditional programmer and room thermostat, and assuming no issues with places to install / wiring access I'd expect it to take between 1 1/2 and 3 hours, plus the costs of the programmer (£80?) and thermostat (£60).
Reply to Can a boiler with a timer be converted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
