Discuss Bye-Directional Electronic Rad/Stat Valve Installation in the USA area at PlumbersForums.net
Is there an optimum position for them on a radiator - meaning position them on the Flow or Return side.
I mean by this - is there a technical argument - If you have a choice (new installation) to say that mounting an Electronic TRV ( more sensitive) on the return side is better due to the less radiated heat to influence the TRV sensor.
Trvs are always best on the flow
Hello Shaun - by saying that TRV's are always best on the Flow side, ''why''!? I have to ask - is there a technical reason or are you going by experience or convention. If I may put my two-penny worth in and pose an argument - could it be argued that putting the TRV on the return side, there would be a lesser transfer of heat radiated/convective to the let us say a more sensitive electronic TRV - ignoring the fact that the TRV's are now bye-directional...joe
Because they are designed for the flow of water to pass a certain way if there installed on the return when they start to shut off they make a loud noise (sometimes a chattering noise)
also depends on the manufacturer but all valves are bi directional but you have to turn the body eg instead of the valve head upwards you must install it horizontally so the flow is exiting the rad
the only true bi directional valve is a danfoss rasc
Reply to Bye-Directional Electronic Rad/Stat Valve Installation in the USA area at PlumbersForums.net
