Discuss Burner motor to Oil Pump Vibration in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I've fitter new motor to Inter 2011C burner which drives Danfoss BFP 11L3 oil pump.
motor bearings are good fan rotates freely and without wobble. There's a vibration noise from the pump coupling area which I just can't seem to solve.
If I slacken the pump mounts and move it slightly noise changes but I can't seem to get it quiet.
Is there a trick to getting the pump aligned with the motor? Is the pump the problem?
Any advice will be much appreciated.
Andy
Not surprised the motor bearing are good if the motor is brand new.
Was the new motor an exact replacement?
I think I know what might be wrong, but you really need to get it done by someone qualified.
Analysers show up badly burning boilers.
Reply to Burner motor to Oil Pump Vibration in the Plumbing Jobs | The Job-board area at PlumbersForums.net
