- Messages
- 5,171
Hey fellers, well this is a bad day for me. Last night, my pump starting screeching. So today i have been going around the house trying to solve the issue. Is it air? Is it the impeller or what?
Well. first things first, i back filled the system from the mains, then the pump starting screeching. Then i hear a dripping noise. Look and the cold feed where an elbow was was leaking. So i go to grab it, and it comes off right into my hands. Straight out the soldered joint.
So, thought that was maybe the problem, turns out not so.
So i take the pump apart, and the bearings in the back are all corroded. Well, the whole back where the bearings are cased is corroded. So I go and buy a circulating pump, put it on speed 3, then tried it on speed 1, all of a sudden, it is dead. I can not seem to get it to work again. The live coming from it at all.
So, i think it is faulty, take it back and get the same pump again, so put it on 3,turn it off and then try on number 2. The same thing happens. It just wont work. I cannot seem to get any power to it or from it to get the boiler to fire. The boiler seems all ok.
So now, all shops are closed until the morning, and I am out of heating and hot water. Grr
Any ideas why these pumps are doing this?
Cheers fellers
Cheers fellers
