What do you use when bricking up old flue holes? Especialy if you have to hang the new boiler over it. Any of you use quick setting mortar? If so which is best / least expensive? Do you match bricks and where do uou source yours?
Discuss Bricking up old balanced flue holes. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ply wall then hang boiler. Whilst it's flushing from outside fit a Thermalite brick, then tooth out the old opening and rebuild. Get 95% of our bricks from local indi merchants. Normally take a photo of brickwork on survey.
Normal sand cement.
Does ply constitute non combustible surface or is it temporary?
Reply to Bricking up old balanced flue holes. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
