G
gates1979
Can you get new rubber washers for drain off cocks i had to drain my cylinder as the cold inlet was leaking. i have tightened the drain cock as much as i can but its still weeping so i drained the cylinder again and stripped the drain valve and the washer had perished and all the washers i had for taps were too big. I managed to fit one washer with a bit of filing around the edge of the washer so it was the right size and its done the trick just so i could get the water back on but would like to do it properly just for peace of mind
