Discuss Boulter Camray 5 Oil Boiler thermostat in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi
We got a Camray 5 Oil Boiler with a timer control panel, is it possible to fit a room thermostat instead or have timer and room thermostat? How would it control both turning the boiler on and turn on the heating pump? Can you get wireless models?
Yes, you can fit any timer / room thermostat (wireless or hard wired) to a Camray 5.
Straight forward connections to disable the existing timer and summer / winter control and implement control by an external device are on the PCB.
Whilst this is a fairly simple operation, I would get a service engineer to undertake the change. It should take no more than an hour.
Reply to Boulter Camray 5 Oil Boiler thermostat in the Oil and Solid Fuel Forum area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
