C
cattlady
Hi, I moved into a new build house few months ago, there have was a problem of radiators going hot whenever hot water was heated up in hot water cylinders. After months of visits, this has been solved by installation of valves under floor which stopped the problem, it took about 10 visits because they did not know what to do. However since then, I have another problem. The control panel in the lounge stopped displaying Outside temperature but instead it permamently has a message Cylinders Charging. Boiler always running and hot (blue light on, green occasionally), it might have been pump.I started powering it off. This has been temporarily resolved by changing thermostat on hot water cylinders, but now the problem seems to be slowly returning, yesterday there was a message Cylinders Charging for 5 hours and boiler became hot. In addition, boiler pump runs permamently again. The builder and installation company deny there is a problem. What should I do? I think it is not normal for boiler pump to run non stop and boiler getting hot when water is not used, it was not like this before. Boiler is Greenstar i2i with outside temperature panel and hot water cylinders.
