Discuss Boiler Switching off Heatline compact s24 in the Central Heating Forum area at PlumbersForums.net
Hi all,
Well i think this is my first thread ,and you've guessed i have a problem so ill get straight into it.
Decided to install some Fernox F3 into my system as i have been cold spots on some radiators,ive used this before and its always done the trick.
Anyway i dropped all the water in the system from a downstairs drain off,but when it came to refilling the pressure gauge decided it wasn't going to play ball it was stuck on 2 bar.So right decided to remove the gauge to see if there was any crud blocking it up,anyway gave it a clean with a needle and refitted it,and that is all i have done.
The problem now is after i cleaned the gauge it's still not working correctly,so decided to refill anyway,but what i'm getting is the Boiler keeps cutting out after maybe two two or three minutes after the burners light.
???Does anyone have an idea as to what might be causing this,its bloody freezing in my house at the moment.
If you have a external filling PRV like the one shown, ensure any isol valves on either side open (+ flexible hose connected up) open the black knob anticlockwise, if pressure still too low (assuming gauge now reading correctly) slowly turn the adjusting screw on top clockwise until you get 1.3/1.5 bar pressure, vent any air while maintaining this pressure, shut black knob when finished.
Reply to Boiler Switching off Heatline compact s24 in the Central Heating Forum area at PlumbersForums.net
A
I have a heatline vizo 24 combi boiler that starts up for a few seconds and then shuts off. This happens with both hot water and heating. If left...
Deleted member 120897
Hi, whenever my Gloworm 18r is on even if I leave it on non-stop for 6 hours the flame symbol for the burner never switches off and the radiator...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the...
