Discuss Boiler spares in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
james the plumb
Hey guys
as the cold approaches and i have a few contracts with maintenance and servicing.
i need to do a van stock for boilers fires etc, i know i cant carry it all but could you guys point me in the direction of what would be easy to carry, thermisters, diaphrams etc and for what boilers. I have a few bit on board but not much. Jus dont wana get caught without the essentials.
thanks lads.
I remember the good old days when all you needed was a box of thermocouples, a couple of pumps and a 3 port valve!
Synchron motors
Pump and valves
3 and 5 amp fuses
Black & White motor head, universal for many combis
WD40
Perhaps a couple of common two and three wire APS's
If you have any Icos/Isars then a primary control board and a couple of electrode kits.
105 diaphragm kits, fit some alphas too. Buy alpha o- ring / washer kit ÂŁ19.00 doesn't ever fail to surprise what it fits.
Reign door seal ( foam with self adhesive bit)
Duo tec electrode , Aav just the top bit fits lots and lots of boilers easy money.
Water tribune for junior 24i
Filling loop
Gasket for ideal logic range. After 3 or 4 years they bit flakey.
Old grundfos head and an ideal compact head. Fits most pump bodies.
Filling loops.
Air duster,
105 pcb and apc
Icos electrode
Regin boiler first aid box. Screw spline nuts are a must!
Quick blow fuses.
Isar pcbs , thermo coupling , blanking meter discs , thermostat
Icos/Isar pcb and ignition electrodes. Baxi 105e thermistors, these fit alot of alpha and a couple of others too. Baxi diaphragm kits, (511117 and 511118 i think..?) Pumps and valves. 3-port and 2-port valves, complete valves and spare heads, and synchron motors. LP522 programmers. Fuses. Basic wired room stats. Thermocouples.
Oil for stuck fans, personally I like La-Co zoom oil. Only discovered it a few months ago. I've used it on 15-20 fans so far and only got called back to 1 and that was still spinning, just a bit noisy.
strike up a relationship wit a spares specialist-not a plumbers merchant playing at it.
They know what sells in your area and could advise what boilers are predominant there.
Reply to Boiler spares in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I've just had my annual maintenance check on my boiler (in title), it will be 8 years old in May this year and is (I think) still under...
2K
Hey all Looking for a consensus on an issue that has arisen. Disclaimer is that my ideal icos 12 boiler Is over 10 years old but has been...
2K
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Was at a house today and their new oil boiler was installed in a pretty shoddy fashion. Aka Plastic tiger loop screwed to the boiler casing...
2K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
