Discuss Boiler shooting up to 4bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rhys23
I'm having trouble rectifying an issue with a Worcester greenstar 24i junior. I have changed the expansion vessel like for like as the old one had ruptured. The tube to the expansion vessel is clear.
However, occasionally the pressure shoots up to 4 bar and discharges through the prv when hot water is running. Sometimes it doesn't discharge and goes back down to 1.25 bar (normal pressure). Most of the time it doesn't rise at all when hot water is running. The customer doesn't use the heating.
The filling loop isn't passing and have checked pressure is correct in new vessel. There are only 7 rads on the system.
Does anyone have any idea what else I can try?
Reply to Boiler shooting up to 4bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
