Discuss Boiler power cable on hot pipe and water pipe pressed on isolator switch in the Central Heating Forum area at PlumbersForums.net
hi, I’m wondering, is this cable safe to be going around the very hot copper pipe as it is and is the white pipe okay pressed against the isolator switch? Gas engineer came to do it today. Just seems a bit risky to me so wanted to check I’m not going die if something leaks or gets too hot.
Not the best I would get a piece of 22mm pipe insulation
Reply to Boiler power cable on hot pipe and water pipe pressed on isolator switch in the Central Heating Forum area at PlumbersForums.net
