Discuss Boiler making whistling noise in the USA area at PlumbersForums.net
Hi Can anyone tell me the reason why my ideal logic boiler is making a whistling noise.
Reply to Boiler making whistling noise in the USA area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
