Discuss Boiler m.i's, negative pressure etc. in the Central Heating Forum area at PlumbersForums.net
I'm trying to compile a list of various boiler types with their heat input, gas rate, where applicable negative fan pressure etc for college. Is there any easy way to do this or do I need to go through each boiler type m.i's one by one to find out? I thought this was a good idea to start with but now I'm not so sure. Thanks in advance for any help and please tell me if you think I'm mad and wasting my time. Regards, mattjam
Thanks for the reply brambles. You're wrong though with regards positive pressure. For example if the fan pressure on the Worcester gr8700wi is under -3.5 mb then the heat exchanger needs cleaned.
What do you need to compile a list for?
Is it a task set by college or is it something you wanted to do for your own benefit?
If it is the latter, I wouldn't bother to be honest. You'll find it if you need it when on the job.
I was referring to boiler types: positive or negative case pressure boilers. Not the pressure differential across a specific exchanger.
Apologies brambles, I see what you mean. Thought it was a good idea, not so much now
[automerge]1582064431[/automerge]
Bit of both LP. Don't think I ll bother now to be honest. Thanks for your input
Reply to Boiler m.i's, negative pressure etc. in the Central Heating Forum area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
Can anyone help, please? I'm looking for a heating system circulation pump for a domestic install, with 3 speeds, where the speed can be toggled...
1K
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Combi boiler system losing pressure every 2 days. We've been topping it up for months now and have had various radiators replaced and flooring...
1K
