Discuss Boiler leaking from ... well, that's what I'd like to know! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I was beginning to think I knew my way around my Vaillant Turbomax Plus boiler, having recently replaced the pressure release valve and repressurised the expansion vessel. But now it's leaking water and, while I can see where it's dripping, I don't understand the function of the component that's leaking. If you look closely you can see a drip just below the hole in the brass fitting. Look forward to hearing what this bit does, and how (if at all) it can be fixed! Thank you.
Hmmm it’s a tricky one but I’d advise putting the cover back on, turning off the boiler and calling out a gas safe engineer as you are not qualified to remove the cover as this forms a combustion seal and you are putting you and your family at risk by working illegally on a gas appliance
I've only folded down the control panel. Not removed the outer casing, let alone the combustion chamber cover. But of course I'll get someone in if necessary.
Just a drop down panel on the turbomax mate.
However. You have changed the PRV which is a safety control device. Which means you do actually need to put the cover back onto
The boiler and get it checked over. You probably will not get much more advice here.
Whilst no one can stop you to tinkering with your own boiler the consequences of you creating bigger problems needs to be set out. If you were to produce a Big Bang by accident if might invalidate your own home insurance, hurt your family and neighbours, and open you to a criminal prosecution...police are hot on this now as it’s an easy prosecution. The work you have already carried out is defined as work to a gas appliance and as such must be carried out by a qualified person. Rob Foster aka centralheatking
Reply to Boiler leaking from ... well, that's what I'd like to know! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least...
Got a replacement combination boiler, less that 1 year old. Noticed some water from the connection pictured. Can't see what is it from the...
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
