Discuss Boiler is firing every 5 minutes or so in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tonytimms
I have a Worcester combi oil fired boiler about 10 years old that has been working ok but recently I have noticed that it fires very frequently, as often as once every 5 minutes, all day. It did not do this before. The thermostat on both the hot water and the central heating seem to work ok but even when I turn it down it still seems to fire just as frequently. My local engineer says it is the cold weather but I can't believe that as it's quite mild at the moment. Hope someone has an idea what causes this.
Regards
Is it fitted with a frost stat? if so it could be set wrong or faulty
You dont have a hot tap dripping/ running in the property. I Know it sounds obvious but is a possabillity
I have checked the hot water tap, it only has one on the kitchen sink and one in the bathroom, the shower is electric. I have also looked under the sink etc and can't see any leaks. The boiler is losing a bit of pressure but not much, probably about 0.5 bar every week.
Regards
I can't think of anything else at the moment, somebody else will though
Turn off the cold supply into the boiler there is an on/off valve on the cold in at the top of the boiler. This will just prove if there is a possibility of a leak somewhere that you cant see, if it stops you have a leak somewhere if not will go to the next stage.
probably about 0.5 bar every week....
We , I mean you ,have a problem Houston.
Thank you for the obvious bad news but what I am looking for is a solution.
Regards
hi, can you fiind/see any leaks on ch system/boiler ? is any water dripping from pressure relief pipe ? what pressure is on gauge when system hot ?
which model is boiler ?
Worcester man...doth though take the mickey???
Reply to Boiler is firing every 5 minutes or so in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
