Discuss BOILER HELP REQUIRED- Glow worm spacersaver mk2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chadman2401
Hi folks,
Ive got a problem with a glowworm spacesaver mk2. Its in the new house we moved into and has been working fine until yesterday. The problem started when the pilot light went out. Ive relit it no problem and then tried to activate heating via the programmer and the fan kicked in but the boiler didnt fire. When i manually activated the hot water,the boiler clicked and fired up. It ran for 20-30 seconds before clicking off,shutting down gas valve and then extinguishing the pilot. Any ideas what the problem could be?ive never worked on or seen one of these boilers so any advice off anyone with experience in this boiler would be much appreciated.
Dan
Hi Dan sounds like you need a gas safe registered engineer to service it bud!
Thanks unguided1,
I am gas safe,just newish to the game and not familier with this boiler,combi's alot more to my fortay ha.
So you recommend servicing it then and it not being a part related problem?
Dan
Pm your gas safe details to a mod and you'll get access to the gas safe section of the forum. Need to get your post count up to 10 first tho.
No gas boiler repair advice is given on the open forum.
Reply to BOILER HELP REQUIRED- Glow worm spacersaver mk2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
