Discuss Boiler Flue rules - help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rahul
Hello,
I am trying to replace a 21 year old G rated boiler in my Edwardian end of terrace house. The combi boiler is in the kitchen on the outer wall. The flue exits into the street on the other side.
The British Gas engineer who came by said that the flue was extending outside my property so it was breaking some new building regulations, therefore he could not replace my boiler with a new one. He said the flue pipe should be within 300mm of my property boundary, but since this wall formed the boundary of my end of terrace house, it is in effect outside my boundary and violating the rules. How is this applicable retrospectively if the house was built this way?
He is asking me to move all the plumbing to the other side of the kitchen so a new boiler can be fitted! This sounds a bit absurd to me. Any advise?
Regards,
Rahul.
First things first don't go with British gas, is that where the original boiler was located. Rules change and it may have been ok for the old boiler flue to terminate there, but the new flue can't due to it crossing the boundary as be said.
As its a combi and the major work to convert had been done why not move the boiler into the loft and exit the flue through the roof?
Extend the flue . Do not get british gas to throw it on the wall or help stink. Get an independent. Post in the looking for section. If you obtain planning permission it will be fine.
planners wont give permission, it comes under building regs and the rules say you cant, BG for once are correct in their opinion.
Thank you. But if the house was built this way in 1907, why am I being penalized now for not meeting building regs? How can they apply new building regs to properties retrospectively?
If you have consent to discharge over a boundary the regulation is dispensed? But like the right to light ( proximity of a building structure or obscure medium to a boundary?)
I've a sneaky suspicion your band G boiler wasn't installed at the time the house was built.
Bottom line is, what you have now doesnt meet current regs, therefore if you install a new boiler it cant go where the old one is, simples. Moses could have knocked your house up, it makes no difference.
You're replacing the boiler aren't you? How is that retrospective?
So the government is happy for me to continue to run a G rated boiler inefficiently but would penalize me for fitting a more efficient and safer boiler ( even though it won't look any different from the outside) Great. I don't see the point in even trying to ration with this logic. What a nice incentive to keep people inefficient!
Stop being melodramatic. Rules change. Accept it.
Because there's nothing you can do about it except comply if you want a new boiler.
Oh go on then, just cos its you, you can do want you want.
Not.
Thats the rules. Keep your old boiler, its costing you the money.
Falls firmly in the categorie of asks question but only wants 1 answer. Begs the question why ask?
I feel your pain. I wanted to insulate my loft (and save the environment by doing so ) using loose asbestos insulation which I was going to blow in but apparently 'the regulations changed' Now I have to use rolls of loft insulation which is much more inconvenient, might not even bother!
*throws toys out pram because I didn't get the answer I want*. :frown2:
Reply to Boiler Flue rules - help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
