Discuss Boiler flue not accessible but builder says it's all one piece in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone. I'm hoping someone can help...
We have recently redone our property and there is a new boiler and flue. The flue enters the ceiling above the boiler and is hidden from view (above a bathroom) until it exits through the wall.
We have tried to get a gas certificate but the engineer can't see sufficiently far to confirm there are no joins in the flue pipe. We'd like to avoid access hatches having just re-done the ceiling, and the builder (who has now gone AWOL) promised it was all one piece.
Can we put a camera inside the flue - might that answer the question? Any other ideas?
Thanks so much
Tony
You will need hatches cutting into the ceiling to verify this. Doesn’t matter if the builder says it’s one piece the next gas engineer can’t verify that
theres joints in the rook space
needs hatches also who installed the boiler?
I’d say it’s too long to be one piece
Thanks - the builder (company now in liquidation, so we're stuck...) said it was one piece - the length is about 2.4m. Presumably it could theoretically be one piece, if we recorded a camera inside the pipe would that work?
If not, would you mind letting me know roughly how much hatches cost?
Thanks!
Thanks!
wont be in once piece max flue length in one piece is 2m but i will be surprised as no on uses them unless they have to
also you will still have two joints one boiler end one flue exit end
best option get a gas safe engy in to re commission and inspect the boiler also get him to fix hatches where the flue runs
Thanks - do you know roughly how much hatches should cost to fit?
depends on a lot of factors
any where from £150 to x amount
do they need to be fire rated are they easy to install best get a quote
Reply to Boiler flue not accessible but builder says it's all one piece in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an Alpha Intec boiler installed on my loft wall. The flue goes horizontally from the top of the boiler and passes through the wall, exiting...
6K
HI, I had a new gas meter fitted a year ago and the installer said he wasn't happy with the flue. I have lost the report but would like to...
Hello, from South Devon. Firstly - I'm not a Gas Safe RGI. I'm considering my options to replace a 23 year old |Ideal Classic FanFare 50,000 kw...
3K
Can I jump in here rather than starting a new thread about the same thing? We were about to start getting quotes for a new combi (just moved into...
9K
  • Locked
I'm hoping for a bit of advice. We are in the process of renovating an old house and as part of that work we are upgrading the old 1980s boiler...
4K
