Discuss Boiler firing for hot water but not for Heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
L
Lee Holden
Hi, I am having an issue with my conventional boiler not firing up when my thermostat calls for the heating to be turned on. I have a Hive Thermostat and Receiver which seem to be working well. The lights turn on on the receiver as per schedules. When hot water is called for the boiler fires up every time, however when the central heating is called for the boiler doesn't fire up.
I can get the heating to turn on by ensuring the heating is being called for at the same time as the water tank is being heated, but nothing happens when just central heating is called for.
Has anybody else had this issue before or know what it could be?
Boiler is a Glowworm 15r
Port valve issue or hive relays not working
Thanks.. I’ve removed the cover of the motorised valve (replaced about 18 months ago) and tested operation. When hot water is already on and heating is called for the valve moves as expected and radiators start warming up. However, it doesn’t move when h/w is off and heating is called for and boiler doesn’t fire. I have also manually opened valve and tried heating and still doesn’t fire. How would I check the Hive relay?
Do you have power at the grey on the port valve when how water is off ?
Reply to Boiler firing for hot water but not for Heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
